4l60e tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2008, 01:00 AM
4l60e tranny
does the TPS have any thing to do with the shiftting
Old 09-11-2008, 04:10 AM
SSedan64's Avatar
I would think it does since the 4L60E is computer controlled and doesn't use a TV/ThrottleValve cable like the 700R4/4L60.
TPS, computer & governor should control shift timing & line pressure, shift firmness etc..
Old 09-11-2008, 07:24 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Yes,
the on board computer in the vehicle receives many signals from sensors for this purpose.
Old 09-11-2008, 08:32 AM
Originally Posted by Crosley
Yes,
as long as you take off normal it shifts an drives fine but the more gas you give it it wants to hold back or if you try to hit passing gear it holds back
2005 4L60E tranny Crosley Transmission - Rearend 8 05-18-2008 02:51 PM
97'C1500 4L60e tranny problem fiolater Transmission - Rearend 3 03-23-2008 08:27 AM
TCC error code P1860 in 4L60E tranny PilotHawK Transmission - Rearend 19 10-18-2005 03:26 PM
4L60E tranny HELP huntingonedown Transmission - Rearend 2 05-09-2004 11:57 PM
can i use a 4L60E tranny & computer with a carb. engine r50max Transmission - Rearend 2 12-14-2002 08:44 AM
