4L60e tranny 4x4 and 2 whl drive? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2008, 09:19 PM
4l6oe
im trying to find out if what i heard was true about the 2&4 wheel drive 4l60e are the same transmission as long as you have the adapter for the transfer case. is it true please help!!!!!
Old 03-25-2008, 10:43 PM
Crosley's Avatar
Wiki Edits: 1659
ricktech:
I split your post out since you are asking a different questions inside a thread.
the answer you look for is "no"
4x4 and 2 wheel drive 4L60E output shafts are different lengths.
Old 03-30-2008, 01:13 AM
Wiki Edits: 85
Same transmission as long as you change BOTH the output shaft AND the tail housing.
