4L60E Tranny doesn't leave 2nd gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2013, 06:31 PM
IrocRacer's Avatar
Ok so here's the layout. 1993 Suburban 5.7 TBI 2WD. Only light on in the dash is the ABS light. This is my friends truck so i will try to give good details. From a dead stop the truck starts to move like normal through first then second but i leave my foot on the gas past 2200 RPM's it will wind out the second gear but if i drop below 2200 when i coast without my foot on the gas then it sounds like its idling and when i it the gas it just revs.i have to manually go to 2nd for me to keep going.I have been reading and forsee 3 Possibilities,1-The cable i have to check from the tranny to the throttle body and make sure it snaps back.2-The speed sensor on the tranny and or 3-Shift solenoids.Any insight on this would be great. thank you. P.S On the tranny i found this number 8680514 with a big 8 on the side so im taking it that this is a 4L60E. If im misinformed please let me know.
Old 05-01-2013, 11:12 AM
If it is a 1993 it "should" have a 4L60E in it. If that is the case, there is NO CABLE.
From what you have typed so far, you have burned up the 3rd & 4th clutch pack. Time for a rebuild.
Old 05-01-2013, 10:10 PM
IrocRacer's Avatar
Oh ok. my friend had told me she took it for inspection and it was fine but when he left from inspection it didn't work anymore.
700R4 2nd gear 4th gear bind up? zutaten_zucker1 Transmission - Rearend 1 02-25-2011 06:24 PM
4l60e feels like park brakes on,no rev. only 2nd gear? 84'Monte Transmission - Rearend 3 09-01-2010 06:57 PM
4l60e Tranny troubles, Skipping second gear! wfobubby Transmission - Rearend 3 12-10-2009 06:59 AM
No reverse gear and slippage in Drive 2nd gear. jadejoky28 Transmission - Rearend 14 04-09-2009 11:49 AM
700R4 2nd gear start/4th gear bind up? myclone1 Transmission - Rearend 3 04-19-2005 02:51 PM
