Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 10-20-2007, 01:27 AM
GMCTRUCKS's Avatar
GMCTRUCKS GMCTRUCKS is offline
4l60e Trans.
I was wondering if a 4l60e transmission from a 96 GMC is built with better parts than a GMC 93 4l60e trans what I mean is like the parts that are always' shelling out on a 93 4l60e tansmission the same on a 96 model or were they corrected with beefy parts?
Thanks! GMCTRUCKS
Old 10-20-2007, 08:11 AM
Crosley's Avatar
Crosley Crosley is offline
Moderator guy
 Crosley's barnstar
re: 4l60e Trans.
Thanks! GMCTRUCKS
not really any changes in basic hard parts
Save the earth , choke a tree .... save a squirrel
Old 10-20-2007, 03:33 PM
curtis73's Avatar
curtis73 curtis73 is offline
Hates liver, but loves Jmark
 curtis73's barnstar
Wiki Edits: 13
re: 4l60e Trans.
The big upgrades didn't happen until 98 when they started calling them the 4L65E. That name never really caught on, though. Its still called a 4L60E
Old 10-20-2007, 03:43 PM
Crosley's Avatar
Moderator guy
 Crosley's barnstar
re: 4l60e Trans.
that is interesting since the earliest use I know of a 4L65E was in a AWD application with a 6.0 liter V-8 in the 2001 Denali GMC.
The L65E upgrades included 5 pinion planetary units, input shaft, out put shaft , 3-4 clutch count.
There is also a 4L70E trans , seems like I read about a 4L75E too.
GM also introduced a new 2nd gear servo size... in between the vette size servo and regular #553 servo size used on V-8 & 4.3 V-6.
Old 10-20-2007, 06:18 PM
performabuilt2 performabuilt2 is offline
re: 4l60e Trans.
if anything thay made them worse with those stupid plastic accumulator pistons
Old 10-20-2007, 06:37 PM
Crosley's Avatar
Moderator guy
 Crosley's barnstar
re: 4l60e Trans.
Photo of plastic piston from a 2002 truck with 4k miles on it next an aluminum piston...
Old 10-20-2007, 06:39 PM
re: 4l60e Trans.
there ya go just like the 3.1 lower intake manifolds always broken
Old 10-20-2007, 07:46 PM
curtis73's Avatar
 curtis73's barnstar
Wiki Edits: 13
re: 4l60e Trans.
You may be right, you are much more in the know than I am. I just started hearing all 4L60E's being referred to L65s in 98 when they went with the removable (shorter) LS-style bellhousing and the 5-pin planet. I've seen a few, and installed a few 98-2001 cars that fit the L65 description, but I have rarely been correct on tranny info when you're involved in the conversation I do know that many of us Impala SS guys looking for upgrades to our L60s turn to 98 and later LS-trannys for the 5-pin planet.
Old 10-21-2007, 11:00 AM
GMCTRUCKS's Avatar
4k60e
Thanks guys for the answers.
Have a Great Week! GNCTRUCKS
Old 10-21-2007, 11:25 AM
Notorious's Avatar
Notorious Notorious is offline
Hot rodder, not street rodder!
re: 4l60e Trans.
If anyone needs it I've got a recommended parts upgrade list for the 4L60E. I'll be using it to build one soon. It was compiled by a specialist who builds these and 700Rs for quite a few folks and with great success. He gave me this list for my specific needs and he says it should be quite adequate for my engine, which makes around 500 lb-ft of torque at the crank.
Old 10-21-2007, 12:43 PM
scrot's Avatar
scrot scrot is offline
re: 4l60e Trans.
How does crap like this happen?
Doesn't GM thoroughly test designs like this before putting them into production?
GEEZZ!
Old 10-21-2007, 01:39 PM
curtis73's Avatar
 curtis73's barnstar
Wiki Edits: 13
re: 4l60e Trans.
Sure they test them. The engineers and designers spend years and millions testing them, then the accountants and executives decide that a plastic part saves 64 cents per assembly and only raises warranty claims 12%, so its a valid change.
Trust me, I worked for YEARS as an engineer for 4 different car companies. The actual amount of our great ideas that make it to production are very few. Some marques are better than others. Some are like McDonalds; use grade F parts that barely qualify long enough to stave off warranty claims, others are like a fine steak house. You pay for it, but the quality is obvious and the prices reflect that.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "4l60e Trans."
C4 trans ident? ptsherman Transmission - Rearend 4 12-29-2004 07:27 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
Allison Trans deseldr Transmission - Rearend 5 10-19-2003 07:45 PM
4L60E Trans Swap MI2600 Transmission - Rearend 3 07-12-2003 11:36 PM
4l60e trans with shift improver BILLCAT Transmission - Rearend 0 07-12-2003 08:02 AM
