Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4L60E trans mount bolts won't tighten up
Old 07-08-2012, 11:02 AM
Ripper 410 Ripper 410 is offline
I use these solid mounts all the time, first I check the threads in the tail housing some people like to tighten them with impacts this usually pulls the threads out of the aluminum if it is I put helicoils in then I use new grade 8 bolts or harder and red lock tight, never had a problem and have on just like it on my personal 98 chevy pick up that I drive daily.
