4L60e trans.problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2011, 11:29 AM
4L60e trans.problem
I have a 98 Olds Bravada with the 4.3 all wheel drive,4L60e trans.I went to go out of town the other day and at highway speed I noticed the trans.slipped out of OD,the RPM's went up but felt like it was still pulling ok in 3rd gear.It did go back into OD if I put the shifter down to 3rd then back to OD but only for awhile then it came out again.Anyway I took it back home and now afew days later I notice that sometimes it feels like reverse isn't working,my driveway is alittle downhill so it does roll back and forward gears seem to be working fine(all except OD)This happened all of a suden could it be needing a complete rebuild or something else?
Old 02-25-2011, 06:32 PM
Is the fluid full? Does it have alot of miles on it? I doubt it needs a rebuild tho. that trans is electronic and has solenoids that go bad regularly. something you can try is to put a bottle of that Lucas oil additive for transmissions. it is a very thick friction modifier additive, it generally fixes problems almost immediatly. I would do an oil and filter change before you put it in just to have fresh fluid in it,
Old 02-26-2011, 12:50 PM
Yes fluid is full,not dark or smell bad,150,000 miles I've only owned it alittle over a year.It seemed to have started suddenly and doesn't slip or act funny in any other gear.I'll try some Lucas in it,thanks.
Old 02-26-2011, 06:14 PM
scrot's Avatar
The 4l60e have a lot of problems. Maybe Crosely can chime in with his recommendation. Did GM ever fix most of the problems with the latest 4l60e?
4l60e trans or not? Scottsdale Transmission - Rearend 7 02-15-2011 04:36 PM
4L60E Trans shifting problem, no 3rd no drive Hockey Dad Transmission - Rearend 1 08-12-2010 10:50 AM
2000 Tahoe W/4L60E trans problem crackrbaby1 Transmission - Rearend 0 04-21-2009 08:12 PM
4l60e Trans. GMCTRUCKS Transmission - Rearend 11 10-21-2007 01:39 PM
4l60e trans. r50max Transmission - Rearend 0 12-12-2002 01:14 PM
