We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 10-18-2005, 06:58 PM
silm man silm man is offline
New Member
4l60e trans question
My original problem with my trans was I only had 1st, 4th and reverse. Took the trans apart found that the 3-4 clutches were burn. So I decide to rebuild the trans myself. Install the trans back in the truck and took it for a road test now I have a different problem. After the road test I noticed that I don't have 3rd or 4th gear. What else could the problem be all the clutches and seal are new and I air check the 3-4 clutches before I install the input assay back into trans
Old 10-19-2005, 03:35 AM
ronb's Avatar
ronb ronb is offline
Did you do a line presure check???
Old 10-20-2005, 04:05 AM
New Member
When line pressure test is peform what will that tell youI don't understand that test. I think I found my problem not sure the 3-4 clutches could have 5,6or 7 plate there a possible that i left one out .Will this cause no 3-4 shift .
Old 10-20-2005, 06:58 AM
ronb's Avatar
A low pressure check would indicate an internal leak? caused by possibly a torn or damage seal?? NO or low pressure= no clutch apply! as far as the question on whether or not you left out a clutch? a clearance check should have been done when it was assembled? Too tight=burned or binding clutches, too loose= no clutch apply or slipping?
Old 10-20-2005, 06:30 PM
Crosley's Avatar
Crosley Crosley is offline
Crosley's barnstar
Wiki editor
Last wiki edit: How to identify a Ford V8
Wiki Edits: 709
the clearance for the 3-4 clutch pack should be .050 to .070.
If you did not verify this and there is TOO much clearance the clutch pack cannot apply & there will be no 3 or 4th gears
At the Bonneville Salt Flats... 130mph is known as First gear ...............
Old 10-20-2005, 07:06 PM
New Member
found the problem one of the 3 -4 clutches was'nt full seat in the input housing and was bend . My next question is clearance I did measure not sure if i did it rigth can someone explain how .
Old 10-21-2005, 11:19 PM
Crosley's Avatar
Crosley's barnstar
Wiki editor
Wiki Edits: 709
the clutch pack clearance is measured just like any other clearance.
perhaps a camparo to a engine valve / rocker arm clearance check would give you an idea of the process of checking clearance in the clutch pack
Old 10-22-2005, 06:28 AM
ronb's Avatar
I give the guy an A for effort in trying to do it yourself! But it sure sounds like you at the least , need a book on rebuilding tranny`s? a Haynes would answer your question`s
Old 10-22-2005, 07:51 AM
Crosley's Avatar
Crosley's barnstar
Wiki editor
Wiki Edits: 709
a book would be helpful since this appears to be a case of replacing parts in the tranny , not rebuilding it. There is a difference.
On the flip side , I have read on this board that there is no Voo Doo to rebuilding automatic trannys.
Old 10-22-2005, 07:18 PM
New Member
I have a book this is my first trans rebuild there was something that I did'nt understand . Took the trans apart again found that the tran kit that I order has performance clutches and the steels in the 3-4 clutch pack has a smaller thickness then the oem oneswhich requre you used more clutches. I remeasure the clutch pack clearance now I understand. Reinstall transmission now it shift into all the gears . Thank you
Old 10-22-2005, 07:27 PM
Crosley's Avatar
Crosley's barnstar
Wiki editor
Wiki Edits: 709
having a book helps.
You did not mention the year of the 4L60E ( or I did not see that) , If it is a PWM lock up system for the torque converter , you would ahead of the game to do add some TransGo parts to correct a PWM problem that 90% of the 60E trannys develop
Old 10-23-2005, 11:50 AM
New Member
1996 4l60e the transgo pwm kit is for 1997 and up and just install a new spring. .
Old 10-23-2005, 03:10 PM
Crosley's Avatar
Crosley's barnstar
Wiki editor
Wiki Edits: 709
1995 was the first year of the PWM lock up system in the 4L60E.
The current TransGo parts are a new valve and spring for the PWM system.
Early TransGo was a new valve and dual spring setup that re-used one of the OE valves.
IF you have a SRTA 4L60E v-body it will be stamped with SERV on it. Then you need a different kit from TransGo since the PWM bore will be larger from boring it out to repair the worn areas
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "4l60e trans question"
4l60e shift point question silm man Transmission - Rearend 2 02-19-2006 03:23 AM
th350 trans question levens Transmission - Rearend 4 12-21-2003 05:45 PM
4L60E Trans Swap MI2600 Transmission - Rearend 3 07-12-2003 11:36 PM
4l60e trans with shift improver BILLCAT Transmission - Rearend 0 07-12-2003 08:02 AM
4l60e trans. r50max Transmission - Rearend 0 12-12-2002 01:14 PM
