4L60e trans trouble in a 99 tahoe - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2012, 01:29 PM
Ready to burn this thing, broke the sun shell, purchased another trans, installed now it has reverse and 1st, will not shift into second unless i am turning like 4000 rpm or I manually shift it, will not shift into drive or over drive.. also think that my vss is bad cause my speedo quit working... Any help would be much appreciated..
Old 08-05-2012, 01:30 PM
ohh forgot to say it has a 60 tranny in it..
Old 08-05-2012, 03:54 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders. I edited the thread title to remove ''help'' , the members here are a smart group.
If your speed-O does not function, your PCM will not know the vehicle is moving and will not shift the transmission.
you may need to fixed - replace the VSS first. I also suggest you check the fuses in both fuse panels if the 1999 tahoe has 2. Check the simple stuff first.
Regarding The replacement trans, do you know this is good unit or a junkyard unit that is ''warranteed'' ?
Old 08-05-2012, 06:55 PM
ty
After I post went back out and went over it again, ohm'ed the vss, fine... started looking up the harness and found a wire broke on top of the case.... Ty very much tho for the info... She bangs the gears just fine now...
Old 08-05-2012, 07:00 PM
btw
new, monster tranny... Junkyard never lol...
97 Tahoe 4L60E transmission Fischerfolks- Transmission - Rearend 2 06-17-2011 09:22 PM
P1870 95 Tahoe 4l60e vongoejr Transmission - Rearend 6 04-16-2011 06:36 PM
Trouble code p1870 95 Tahoe vongoejr General Rodding Tech 2 04-15-2011 11:29 PM
2000 Tahoe W/4L60E trans problem crackrbaby1 Transmission - Rearend 0 04-21-2009 08:12 PM
