4L60E trans wireing questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2008, 08:07 PM
4L60E wireing
what all would i need to wire a 4l06e
or could i just change the gears manually while driveing
Old 11-27-2008, 08:42 PM
SSedan64's Avatar
An aftermarket computer or the complete engine/trans, computer and harness from a donor car so you'll have all the engine sensors.
No.
Old 11-27-2008, 08:55 PM
any ideas about where i could get an after market kit
all im useing the truck for is a toy for the woods
Old 11-27-2008, 09:13 PM
4L60E trans help needed
pulled out a 700r4 that was trashed
and found a good deal on a 4l06e now i need to know about the wireing or any after market wiring to use
im only gonna use this truck as a trail truck so maybe i could just drive it like a column shift while driveing
HELP ME
Old 11-28-2008, 07:06 AM
Kevin45's Avatar
Just one of the guys
What year of truck is it going in and yes you can get an aftermarket computer to work with the 4l60E trans. I think Jegs carries it but runs around $400 IIRC. '93 trucks was the changeover year to the elctronically shifted 4L60E. Before that it was the 700R4 or the 4L60. I know that when I built up my '93 from a V6 to a V8, the computer and trans was kind of a thorn in the side. The computer also drives the speedo and the odometer. The 4L60E does not have the cable to drive the speedo.
Old 11-28-2008, 07:26 AM
Crosley's Avatar
Wiki Edits: 1659
The transmission is a 4L60E if there is a round electrical connector on the passenger side of the case. It is about 1.5 inches in diameter . There is NO cable hook up on a 4L60E trans.
You need a controller for this trans. It controls the shifts and main line pressure. With out a controller the trans operates at max line pressure ful time. This will heat up the transmission and wear out the pump quicker.
CompUshift.com has a very good controller.. costs more money though.
Check with Jegs and Summit racing for controllers or Google for other leads to a controller
Old 11-28-2008, 08:21 AM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
Probably cheaper to install a TH350 with a 9" tailstock.
Driveshaft shouldn't need to be cut.
Old 11-28-2008, 08:45 AM
Crosley's Avatar
Wiki Edits: 1659
I would be curious if this trail truck is a 4x4 vehicle?
700R for 4L60E swap? flynbrian48 Transmission - Rearend 6 01-29-2009 10:56 PM
2005 4L60E tranny Crosley Transmission - Rearend 8 05-18-2008 01:51 PM
98 astro 4l60e what swaps out? 3rdgenLT1 Transmission - Rearend 4 06-06-2007 09:16 AM
4L60E rebuild kit ????'s Turbonoma Transmission - Rearend 0 04-14-2007 12:10 PM
questions about 4l60e 85ta383 Transmission - Rearend 3 04-10-2005 08:27 AM
