4L60E Transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2004, 03:49 PM
New Member
4L60E Transmission
Hello!
I would like to know what the trick to installing the 2-4 power band assembly.
Old 08-21-2004, 02:25 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
Are you talking about the servo on the side of the case or the actual band into the tranny case during an over-haul ?
Old 08-22-2004, 07:51 AM
New Member
4l60e 2-4 band inside tranmisson need help
I am talking about the band inside the tranmission . I am not doing a overhaul just change the output shaft to a 2 wheel drive shaft. I am having a hard time with the 2-4 band . I install the band lock aganist the pin and aganist the servo when I try to install the drum assembly the band comes out of place, I try removing the servo and pushing aganist the band no luck is there a tool for this , .Thank you for you help
Old 08-22-2004, 08:49 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Re: 4l60e 2-4 band inside tranmisson need help
the band is installed after the drums are in.
Slide the servo side of the band in first while pushing the drums away with a large screw driver.
DO NOT gouge the surface of the drum with the screw driver. Do NOT bend the tabs on the band to ease the band in!
this what you should see...
