4L60E transmission case damage - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2012, 03:41 PM
Working on a 1998 Chevy k1500 5.7 350. 4L60E trans. There appears to be some cracks in the rear of the trans case. Also, some pretty large spots slightly smaller than a bb out of the valve side of the case. Does any of this mean I need a new case? Can or should I repair any of these areas?
ID:	66982   Click image for larger version
Old 07-25-2012, 01:04 AM
Wiki Edits: 85
The first pic is nothing to worry about.
In the second pic, those do not look like cracks to me.
The Following User Says Thank You to mmerlinn For This Useful Post:
abbazabba (07-25-2012)
Old 07-25-2012, 12:43 PM
So no need to worry about any sealing issues with the valve body? Should I file those spots and round them off a little. They are pretty rough spots. That second picture with the cracks look almost like the case coating of some sort if peeling. Thanks for the input!!
Old 07-25-2012, 12:52 PM
SSedan64's Avatar
Take a piece of glass with fine wet/dry sand paper & make sure the Vbody & Case is flat, no high/low spots. 2nd Pic looks fine, just from casting etc..
The Following User Says Thank You to SSedan64 For This Useful Post:
4l60e case ball check location vanislejames Transmission - Rearend 2 04-19-2012 11:00 PM
Can a 1999 4l60e case be used for 2002 with bad case lugs misterchevy Transmission - Rearend 3 02-26-2012 06:20 AM
Transmission damage from ocasional towing 406 bug Transmission - Rearend 11 08-02-2010 06:01 AM
Did I Damage the Transmission? NAIRB Transmission - Rearend 2 09-25-2005 08:37 PM
Will I damage my transmission? Marcus Transmission - Rearend 3 04-17-2005 02:54 PM
