4L60E transmission neutral switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2009, 01:04 PM
I have a 1996 Chevy S-10 with a 4L60E transmission, can anyone tell me what wires go to the neutral safety switch? I would like to jump out the switch. I had the transmission replaced a week ago & today the truck will not start. Everything electrical works (headlights, horn, radio etc.) & a battery jump did not help. Any other suggestions would be appreciated . When I turn the key there is no click or any noise. thanks bill carnutbill@msn.com
Old 06-11-2009, 02:10 AM
SSedan64's Avatar
Sounds like your starter wires may have been damaged/pinched during the swap.
Old 06-11-2009, 11:24 AM
Most likely it's an adjustment problem with the switch position. Which is to say they didn't get the switch or the external shift mechanism adjusted properly. This thing is really sensitive to position/alignment, I'd take it back and have them set it up properly.
Bogie
Old 06-11-2009, 02:55 PM
fast68's Avatar
likes chevy trucks & boobies
if you hold the switch in crank position and run the shifter up and down will it do anything ever at all ?
if not then id vote for it not being safety neutral switch issue unless its unplugged somehow ?
solenoid or wire issue most likely or wires pinched possibly yeah
check starter wires closely
safety switch is either on shifter assembly or on the column, if its column shifter equipped
good luck
Neutral Safety Switch on TH-350 nova69 Electrical 5 11-22-2007 04:01 PM
neutral safety switch on a stick? chirpn69 Electrical 14 03-05-2007 04:30 AM
need help with neutral safety switch Grey1961 Electrical 5 12-11-2005 11:22 PM
neutral safety switch jwash56 Electrical 2 05-24-2005 10:27 AM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
