4L60E transmission problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2009, 09:23 AM
4L60E diagnosis help please!
I have the 4L60E in my 03' Chevy TB EXT. While cruising up the mountain yesterday it would not shift out of 2nd or possibly 3rd gear. I got a high rev (5K) to maintain a 70 mph then lowered it 55 mph and the revs reduced to 4K. Checked fluid level which was well above the full line.
Question...this seems to be a common problem with this tranny but what is the usual fix?
Thanks
Old 01-26-2009, 01:32 PM
more info
I also get no dash warning that anything is wrong? I drove it again today after leaving it in the garage overnight but nothing has changed.
Old 01-26-2009, 06:35 PM
tnsmith10's Avatar
when will it rain???
have you had the vehicle checked for codes? does it have reverse still?
whats the fluid level and condition?
have you had the transmission serviced recently?
more info please
Old 01-26-2009, 07:03 PM
if it wasnt going into 4th then you may have a servo seal leaking if it was not going into 3rd most likley the 3-4 pack is gone
