4L60E trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2011, 09:29 AM
retired USMC's Avatar
4L60E trouble
I have a 97 c1500 with the vortech 350 and the 4l60e 2WD. I had the tranny rebuilt about 16 months ago and now it's giving me trouble. When i try to go forward in od it feels like my brakes are applied, but if i shift it down to 2nd it drives off ok. Any ideas? I have checked the fluid levels and it's fine. I have no leaks and once I'm moving it drives like normal. Please help me.
Old 11-12-2011, 07:15 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Sounds like a probelm in the 2nd gear circuit. Cracked or worn out accumilator or in the 2nd gear servo. By-passing oil to apply the band when it should not be applied.
You shift to 2 and the vehicle drives... shift to third gear the oil from 3rd gear forces the servo off... then in over drive the band is back applied
Old 11-18-2011, 09:28 AM
Well thanks for the reply, but I finally took it to aamco, and it turned out to be the shift Solenoids. they replaced both a and b and now it runs just a good as ever, but thanks again!
Old 11-18-2011, 05:47 PM
SSedan64's Avatar
Glad it turned out to be something simple.
GM 4l60e trouble bryanbaranuk Transmission - Rearend 1 10-17-2010 10:07 AM
4l60e trouble vr commodore Transmission - Rearend 4 01-08-2010 01:52 PM
4l60e sonoma trouble dlanod Transmission - Rearend 2 10-25-2007 01:48 PM
4L60E Trouble StrtCrazed4Life Transmission - Rearend 2 04-20-2004 08:28 AM
4L60E trouble with overdrive Please Help Transmission - Rearend 2 03-19-2004 07:20 AM
