Hotrodders Bulletin Board
#1
4L60E valve bodys
I am to the point on my 4L60E where the valve body is the only thing to finish.
I found a guy on E-bay that is selling dyno tested valve bodys with the sonax TCC upgrade and all the electronics tested for $159, then there is a $30 core, and like $15 shipping. I found the Sonax TCC reamer for $102 plus the cost of the valve. Whats everyones opinion on buying vs doing it my self??? Keith
K-Star Automotive Performance Engines The crash was easy: rehab is killing me-"John Force" |
#2
re: 4L60E valve bodys
Hi Keith,
Hope things have gone well for you since I've last seen you, I've been meaning to stop by but each time I'm over there it's late, I'll make it before to long. As for the VB, I think the testing don to the VB is worth the extra money, unless your able to do that yourself also. Take care, Rich |
#3
shop
Rich, you are more then welcome to stop by any time..
I can show you my new toy i built. Keith
#4
You must match up the 4l60e v-body , there are a couple of different designs.
I use the TransGo PWM valve for the v-body. No need to have the Sonnax tools
======== If you can't fix it with a hammer, you have an electrical problem. |
#5
trans
Crosley, thanks for the tips. Do you use a full trans go kit in the 4L60E’s ?? If so can I get the part number from you?? Or can I get the parts numbers of the individual parts that you use.. Do you replace all the solenoids?? Or just do the ohm test??
Keith
#6
4l60e
Keith, I also use the transgo PWM valve for our units, we buy the transgo kit for our rebuilds.
I'm not at the shop right, and won't be back until saturday, If Crosley is not able to respond with the part # by saturday, I will post it. |
#7
Small TransGo kit... SK 4L60E
NATPRO # k51944E In an ORANGE box
#8
kit
Thanks for the part number..I will order it this afternoon.
Keith
Back to top |
Similar Threads for: "4L60E valve bodys"
| 4l60e boost valve difference???? | 8843astro | Transmission - Rearend | 5 | 03-24-2007 11:37 AM |
| Valve Stem Angles, Do they Matter? Truth or Fiction? | QuenchPiston | Engine | 35 | 12-28-2006 09:11 AM |
| 700R4 – Why are the TCI manual valve body instructions so lousy? | Bayley | Transmission - Rearend | 20 | 05-26-2006 05:48 PM |
| oil being sucked threw the pcv valve on my 350 sb.. | Robbie | Engine | 23 | 05-08-2004 08:12 AM |
| Residual Pressure Valve?? | Dave E Shank | Suspension - Brakes - Steering | 1 | 12-27-2002 06:12 PM |
