4l60e valve boost spring - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2012, 04:10 PM
My valve boost springs appear to be too worn to reuse. I'm having a hard time finding the replacement springs. Any suggestions?
Truck is a 98 Chevy k1500 5.7 350
Old 07-28-2012, 04:20 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
that is not a valve boost spring. Those are release boost spring device for the 3-4 clutch pack.
Sonnax offers new replacement springs
The Following User Says Thank You to Crosley For This Useful Post:
abbazabba (07-28-2012)
Old 07-28-2012, 05:55 PM
Thank you.
Old 07-29-2012, 09:29 PM
Last wiki edit: Window removal and installation Last photo:
Wiki Edits: 11
Actually 3-4 shift cushion springs. Old school recommendation was to discard these for a better (more noticeable) 3-4 upshift. Nowadays rebuilders mostly leave them in. If you get your hands any one of the older 700R4 or 4L60E ATSG rebuild manuals you can find in each a clear recommendation to discard these springs.
You can take this two ways. One, toss the springs. Or two. Find a transmission shop that's been in business more than a few years and they will likely have a box of the springs somewhere in back from where they've been removing them over the years.
Personally, I put the spings back in. They are a bit of an odd design but I've never seen any "worn". At all.
The Following User Says Thank You to GypsyR For This Useful Post:
abbazabba (07-30-2012)
Old 07-29-2012, 11:46 PM
pricesgarages's Avatar
get the sonax one or order them threw gm best to replace them on any rebuild i personall y have tryed leaving them out didnt notice mutch diffrence in shift firmess i like using them because they keep the clutches from applying to early also will allow for tighter clutch pack clearences thats were you can inprove the shift quility
The Following User Says Thank You to pricesgarages For This Useful Post:
Old 07-30-2012, 09:50 AM
Thanks for the info.
GypsyR- what I mean by worn is that new springs measure right around 1 1/8th" but most of the springs I took out measure closer to 1".
I will probably try and replace them.
Old 07-31-2012, 04:17 PM
Wiki Edits: 11
There are places in a transmission where a thousandth of an inch is important. That isn't it. As has already been said, you can leave them out completely and find little difference. I always put them back in but that 1/8" wouldn't interest me in the least. I'd throw them back in as is and never think of them again. If you think not replacing them will be sticking with you and bothering you, buy new ones. Peace of mind is worth a lot.
abbazabba (07-31-2012)
Spring Pocket Vs Spring Size vs valve lenth Help Needed swompz Engine 16 05-30-2012 10:25 AM
4l60e boost valve installation reddeth Transmission - Rearend 4 06-14-2009 09:35 PM
Bunch of trouble with HD2 boost valve for 4L60e jemo Transmission - Rearend 2 03-13-2009 08:23 PM
4l60E pressure regulator boost valve impalaman63 Transmission - Rearend 1 01-06-2009 07:11 AM
4l60e boost valve difference???? 8843astro Transmission - Rearend 5 03-24-2007 12:37 PM
