4L60E , whats this wire for ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2006, 06:26 PM
Vortech 4.3's Avatar
jack of all trades
the speed sensor, the harness going to it. there are 2 regular wires, going to the computer. but, there is a ground wire that runs down "close" to the sensor. where it turns in a "bare" hard wire. this turns and goes all the to, but not "into" the computer. all this is wraped in a foil lined liner.
thanx
Old 04-10-2006, 07:18 AM
tnsmith10's Avatar
when will it rain???
i would check the o2 sensors. thats what ive seen on the late model gm's
Old 04-10-2006, 08:15 AM
Crosley's Avatar
Wiki Edits: 1659
the signals from the speed sensor can produce "noise" that will cause computer troubles if they are not cancelled out. Usually you will see the speed sensor wires are twisted around each other the full distance from tranny on up the harness.
this helps cancel out any electronic "noise" that would cause computer glitches.
Could explain the wire in question
Old 04-15-2006, 09:42 AM
jack of all trades
Crosley. thats what it is.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 29 06-18-2009 06:54 AM
new welding wire oldred Body - Exterior 93 05-07-2009 04:40 PM
1986 Cutlass wiring Q's again :( ChrisMiddleron Electrical 12 07-16-2005 04:22 PM
One wire or three wire? Screwy Lewy Electrical 0 06-30-2003 04:33 PM
57 Chevy generator to altenator swap Rodrunner Electrical 2 07-17-2002 09:59 PM
