4L60E whining in 2nd 3rd and OD but not 1st - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2007, 03:52 PM
I have a 1998 Silverado. 2WD 5.0 Litre. I believe it has a 4L60E transmission and it whines like a woman in 2nd 3rd and OD. I can't find anthing on the net that explains the problem and why it only does it in these gears and not 1st gear. Can anyone out there please help me figure out this whining so I can shut it up.
Thanks
Old 08-17-2007, 09:15 PM
airworld2's Avatar
700 whine
internal bearing will cause this trouble, needs to be taking apart and look at bearing between input sprag and drum .
airworld2
4L60E shift problems remington7 Transmission - Rearend 20 09-21-2007 08:34 PM
700R4. No 2nd Gear, Slips in OD CedarGrove Transmission - Rearend 3 07-29-2006 12:00 AM
700R4 2nd gear start/4th gear bind up? myclone1 Transmission - Rearend 3 04-19-2005 02:51 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
1st, 2nd, 3rd! No 4th gear Deadtemple Transmission - Rearend 6 10-15-2003 08:15 PM
