Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4l60E will not move
Old 10-13-2013, 11:54 PM
C-cab dreamer C-cab dreamer is offline
You did mention that the tranny fluid was burned. There's always a reason for that, and whatever the reason is - it isn't good. Burned hydraulic fluid doesn't work the same as new, and if you expect to get another few thousand miles out of your vehicle, you should change it and the filter PDQ.
