4L60E will not move when it warms up - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2008, 05:44 PM
I have a 1994 chevy silverado with around 200,000 miles on it. It has a rebuilt 4L60E in it.Now it only runs for a few min. when it is cold.After it warms up it will not move.I don't know what the problem is. Can anyone help?
Old 03-30-2008, 09:21 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
What does the shop say that rebuilt it?
Out of warranty now?
How many miles since the rebuild?
A filter clogging up could run for a few minutes then quit.
Have you pulled the pan and looked inside the filter too?
This could be several problems causing no movement when 'hot'
Does this truck have a deep factory pan on it? The bottom of the pan is not flat.. there is a step up near the back side of the pan.
Some folks use the wrong filter with the deeper factory pan. The filter can fall out of the pump
Old 03-31-2008, 11:38 AM
sharpe427's Avatar
Is the fluid full??? All the comments above were spot on, SOMETHING is making a pressure loss inside the trans. Burned fluid, leaking filter, low level, shift solenoid broken..the list could be pretty long so start at the basics...fluid and filter.
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 09:24 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 09:20 AM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
