4l60e won't select gears after rebuild, who can solve this one ?? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-31-2011, 11:59 AM
old yukon's Avatar
OK, the t/case was not engaging.
Pulled the battery terminal, an reconnected it.
Then turned on the engine and pressed 2Hi on the t/case selector.
No gears still but the grinding noise has gone, when selecting through all the gears.
Any bright sparks out there with an idea?
  #17 (permalink)
Old 06-02-2011, 07:14 AM
old yukon's Avatar
I ended up following the good advice of Tnsmith10 to check the linkage between the rooster cone and the manual valve.
He was spot on, it must not have been fully engaged, and had fallen out. Such a little thing causes such big problems.
Thanks for that Tnsmith10.
I got gears now, I could never believe seeing the back wheels rotate on a raised up rearend could be such a beautiful sight.
  #18 (permalink)
Old 06-02-2011, 07:18 AM
tnsmith10's Avatar
when will it rain???
glad your getting it whooped there bud, have you had a chance to drive it yet to see how it shifts through the forward gears?
and were you able to get the encoder motor back on the t-case?
  #19 (permalink)
Old 06-02-2011, 07:36 AM
old yukon's Avatar
Could'nt resist the temptation!
I lowered the thing quick smart, gave her a wash, and filled her up, inflated the tires, and cruised along the roads in the early hours of the morning, without skid plates, with guards, and even without the encoder motor.
filled the truck full of shopping and got cruising back home, it was such a pleasant and but strange felling after sooooo long.
Thumbs up to all those who helped!
Thank God Im back on the road again, a few more things to finish off and my wife is ready to pack those tools away.
  #20 (permalink)
Old 06-02-2011, 07:41 AM
tnsmith10's Avatar
sweet deal! glad its going again.
  #21 (permalink)
Old 06-02-2011, 10:32 AM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
Good to here!
Wife packing up tools?
Does she have a sister?
  #22 (permalink)
Old 06-02-2011, 12:05 PM
old yukon's Avatar
She one of kind 123pugsy !
  #23 (permalink)
Old 06-02-2011, 02:14 PM
SSedan64's Avatar
This has been a 'Project', glad to see you're rolling again Yukon.
  #24 (permalink)
Old 06-02-2011, 07:27 PM
tnsmith10's Avatar
my wife likes to help do the work, she finds it offensive to be the tool chaser. i let her do as much as i see she can handle and, after over 10 years of marriage, shes learned quite a bit. like you said bud, 1 of a kind...
4L60e, to rebuild or not rebuild, that is the question ? old yukon Transmission - Rearend 31 04-07-2011 12:25 PM
no forward gears on my 4L60e, what up... old yukon Transmission - Rearend 6 12-18-2010 11:20 PM
4L60E no gears after rebuild silver12 Transmission - Rearend 1 05-02-2010 11:02 AM
4L60E/No gears noviceshadetree Transmission - Rearend 4 02-08-2008 12:04 PM
4L60E No Forward Gears only year old 327amc Transmission - Rearend 14 10-24-2006 07:36 PM
