4L60e wont shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2008, 11:02 AM
4L60e wont shift
i have a 98 s10 with only 64,000 miles on the tranny and the motor, an for some reason the tranny will no longer shift unless i got on it till about 30mph 1st gear an then let go to shirt to 2nd.. if i get on it when im doing like 50mph it will want to shift to 1st... i dont think its geting out of 1st an 2nd gear either. any suggestions? thanks
Old 01-14-2008, 11:13 AM
4l60e
Do you have a check engine light on, since you have had these trans problems?
Also, to qualify this concern, it has a first gear start, with a late upshift?
Does it have reverse?
And you have a donwshift into what feels like first, when you are going about 50 mph and you put your foot into it?
Old 01-14-2008, 12:11 PM
yes it does have reverse, an when im way past 1st gear doing about 50mph, if say i wanted to go faster if i stomped on it, it will kick down to 1st with no power, so i have to feather the gas all the time after it shifts into second. an no there is no check engine light on or anything
Old 01-14-2008, 12:13 PM
one other thing to... on my column where it has p r n d 1 2 3... it will go into park, reverse, drive, an only 1st gear.. not 2nd or 3rd
Old 01-15-2008, 07:49 PM
airworld2's Avatar
4l60e
I think you mean PRND321?
airworld2
Old 01-15-2008, 08:08 PM
ya my bad thats what i meant.. thanks
Old 01-16-2008, 11:20 AM
4l60e
Since this transmission is electronically controlled it should be scanned for codes.
Even with no check engine light on, there may be information captured in the system that may help with diagnosis.
It would be best to interface with a scan tool capable of watching the data stream.
Old 01-16-2008, 08:17 PM
sounds like the band or servo
4l60e no shift jkotila Transmission - Rearend 2 10-01-2007 01:46 PM
4l60e won't shift out of first 50 chevy p/u Transmission - Rearend 6 07-28-2006 08:43 AM
4l60e shift point question silm man Transmission - Rearend 2 02-19-2006 03:23 AM
4L60E Shift Problems chianesi Transmission - Rearend 11 01-10-2006 03:16 PM
4l60e trans with shift improver BILLCAT Transmission - Rearend 0 07-12-2003 08:02 AM
