4L60E working without computer - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2006, 06:51 PM
south65ss's Avatar
Hi everybody. Is there any way to make a 4L60E work without computer? It won´t work at all without it or wont work correctly?
Thanks!
Old 07-13-2006, 09:50 PM
FOHLDMON's Avatar
0-100 in 2.7 seconds
4l60e
Hello im tommy,a 4l60e is a electronic trans,in allmost all cases this transmission can not be bypassed with out extensive knowlage of how the shift silinoids-epc-converter silinoids work. allso shift points will be harsh and probly not function for long or at all with out voltage being applyed to the silinoids ect...there are some after market test boxes made for shopes to plug and play/drive the vechial but again this almost all ways defalts the epc electronic pressure control to defalt to full on pressure wich leeds to harh shift patterns.hope this helps.fohldmon
Old 07-13-2006, 10:10 PM
Crosley's Avatar
Wiki Edits: 1659
the 4l60e requires a controller or computer hooked to it to shift automatically & main line pressure control .
TransGo has a kit to convert the trans to vacuum controlled main line pressure and FULL manual only shifts. There may be other kits availible that I do not know of.
One Brake Light Not Working HotRodMan Electrical 5 12-25-2005 09:51 PM
computer controlled timing propaniac Engine 7 06-10-2004 07:31 AM
86 suburban computer bigjak Engine 2 02-07-2004 03:02 PM
83 bronco computer. Jared Electrical 3 11-06-2003 09:29 PM
Computer controlled tranny retro fit. Controll your shift points/line pressure. lykan Transmission - Rearend 1 10-16-2003 10:27 PM
