Hotrodders Bulletin Board
#1
4l60e Year Interchange
I have a 4l60e from a 94 minivan and I know a guy that needs one for his 98 Chevy Express 5.0 liter van. Does anyone know if this can work?
Thanks, Pugsy |
#3
re: 4l60e Year Interchange
I think it was a 4.3 v-6.
#4
The 4.3V6 & 5.0-305V8 have the same bellhousing pattern so it will bolt up. I think it will work. Maybe Crosley will be on here later & I'm sure he can tell you for sure about the other things, wiring, converter, flexplate etc.
#5
I'm thinking there might be differences in the electronic controls, ECM ?
#6
the 1994 will not retro fit into a 1998 vehicle..
there are lock up strategy control differences. The 1998 vehicle may be a 3 piece case trans (bell housing un-bolts)
======== Be kind to your children... some day they may be decide what nursing home to put you in |
#7
Thanks for the info.
Pugsy |
#8
Won't work.
98 and up have a detachable bell housing and the total length of the transmission is different in addition to some of the other comments above. The 94 will work in some 95-97 applications, but ONLY if you cobble together a cable bracket to mount the shift cable to. Most 95 and up to present applications require that cable mount. 94 and back have no provision for it. |
#10
no. the 2003 vehicle will have a LS series engine. Different converter design , the bell housing is different depth , the input shaft & pump stator design is different from the 1998 vehicle. The 1998 Sierra may or may not have a detachable design bell housing . 1998 is considered the first year of the bolt on bell housing 4L60E trans.
#11
So what can I use? I am looking for a core to rebuild and swap in I can not have the pickup down for more than a weekend.
1998 GMC 2WD 1/2 ton 5.0 (305) Vortec 4L60E Thanks AJ |
#13
nope. You must use a 3 piece case trans that is not bolted to a LS series engine. GM introduced the new LS series engine in trucks in 1999. I believe GMC trucks were first with 4.8 and the 5.3 engines. The trans with the LS engine has a different design torque converter , input shaft , stator support shaft on the trans. They are not interchangeable.
#15
You must use a detachable V8 Chevy bell type transmission that does NOT have a bolt on the top point of the transmission. Also, the input shaft MUST have a polished tip.
Back to top |
Similar Threads for: "4l60e Year Interchange"
| 4l60e tag id # | mchl_shafer | Transmission - Rearend | 3 | 05-25-2008 06:26 PM |
| 4L60E interchange | Ohio-Dan | Transmission - Rearend | 1 | 02-23-2007 05:10 PM |
| Hollander Interchange? | Longboard | Hotrodding Basics | 3 | 04-03-2006 08:15 AM |
| 4L60E interchange question | Jessie | Transmission - Rearend | 5 | 01-05-2005 05:35 PM |
| 4l60e year swap | j_labossiere | Transmission - Rearend | 5 | 10-06-2004 04:59 AM |
