Hotrodders Bulletin Board
#1
4l60e year swap
Hey all
Just wondering if a 93 Astro RWD tranny would bolt into and work in a 95 Safari chassis. Both have the HO V6 and both are RWD. The dealership said the 95 was a special "one year only" thing, but everywhere you look to buy these transmissions, the years span from 93-95. Both are 4l60e's. Just need the one in while the 95 gets rebuilt. Any help would be greatly appreciated! Thanks a bunch Jordan |
#2
4l60e
93-94 will interchange, 95 up pump and valve body wont fit or should I say wont work correctly with 93 94 computer with out knowing what to use from one to another.
#4
4l60 e
makes a better swap from 93 to 95 update never try ed that...
most the time 93 would be better off with 92 700 rather than 93 4l60e. but that year can still be rebuild with some improvement and made to last.....I have installed complete 95 using the wiring from 93 without any side affects |
#6
4l60e
I have not performed that swap with computer only transmission but if you have trouble you can swap the computer back to old 93 and install inside trans wire harness to the 95 trans
