Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4L60E Yoke Leak?
Old 02-18-2013, 02:31 PM
painted jester's Avatar
painted jester painted jester is offline
Last journal entry: 383 BLAH, BLAH.
On the universal end of the yoke is a plug like a freeze plug! it plugs the hole (the end) after machining the spline grooves! that plug can leak and is easily replaced. Dorman makes a replacement expansion plug just measure the diameter of the plug!
You have to pull the yolk and universal and put a drift pin ( punch) down the yolk and knock out the plug when replacing the plug, a little sealer on the edge will help seal it!
Jester
