Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4l65e rebuild
Thread: 4l65e rebuild
Old 02-15-2013, 06:39 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
I would scan the system with a proper scanner for live data feed. See if the trans is commanded to shift correctly or not.
the same scanner should be able to manually command the transmission to verify commands are traveling through the chassis wire harness
