Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4l65e rebuild
Thread: 4l65e rebuild
Old 02-24-2013, 06:40 AM
fishcrazy fishcrazy is offline
After installing the new pressure plate the transmission seems to shift normal EXCEPT for the one time it flared from the 2-3 shift. Only did it one time but it has done that before on a couple occasions. If I am not mistaken it was after I ground off the pin. At any rate it seems to be shifting ok now except for the one time issue mentioned. I will test driv eit again today to see if it remains good. It has not reset the CEL which is on. Do I need to disconnect the battery to reset that or do I have to have the codes reas to reset it or will the vehicle reset it eventually since the problem was fixed?
