Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4l65e rebuild
Thread: 4l65e rebuild
Old 02-24-2013, 07:54 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by fishcrazy View Post
After installing the new pressure plate the transmission seems to shift normal EXCEPT for the one time it flared from the 2-3 shift. Only did it one time but it has done that before on a couple occasions. If I am not mistaken it was after I ground off the pin. At any rate it seems to be shifting ok now except for the one time issue mentioned. I will test driv eit again today to see if it remains good. It has not reset the CEL which is on. Do I need to disconnect the battery to reset that or do I have to have the codes reas to reset it or will the vehicle reset it eventually since the problem was fixed?
The DTC need to be properly cleared. disconnect the ground at battery for a while
