4l65e rebuild - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-24-2013, 08:34 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
If the CEL is on, you have hard codes set. Need to scan or try local budget auto parts place may have a basic code reader for use
  #17 (permalink)
Old 02-24-2013, 08:46 AM
I did clear the code when I reconnected the battery. Drove the car for some time just now and I am getting the somewhat soft sloppy shift sometimes. I once got a flare in the 3-4 shift but only once. When I say flare I mean the RPM goes up like it istemporarily not in gear and then catches the next gear. Like the band and the 3-4 clutch pack apply are not properly synchronized. Could this be as simple as the solenoid pin travel is too loose. I have read that the tighter the travel the more firm the shift becomes.
Can this sloppy soft shifting harm the 3-4 clutch pack? Any thoughts?
  #18 (permalink)
Old 02-24-2013, 08:49 AM
the code that had the CEL on was scanned the other day by the tranny shop but they did not reset the code when they scanned it. It was the code that told me the pressure manifold switch was bad.
  #19 (permalink)
Old 02-24-2013, 09:24 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You need the hard DTC cleared so the system does not try to compensate for it. Some codes affect the system more than other codes
Most basic code readers can clear codes. Even Harbor Freight scanners can do that.
If you have the servo pin length all jacked up = incorrect, that can cause 2-3 shift timing problems. So can incorrect clearance setting in the 3-4 clutch pack
  #20 (permalink)
Old 02-25-2013, 09:25 AM
I know that the vehicle computer has an adaptive learning feature but I am not sure how that is changing things due to the codes that were set and how long it takes to stop trying to compensate for a code that is cleared. I did clear the code which was related to the pressure switch malfunction but I have only driven it one time since it cleared yesterday and it did flare one time. I am going to replace the servo pin with an oem pin and see what the travel looks like and see if that fixes the flare.
Thanks fo rthe help. Jim
  #21 (permalink)
Old 02-27-2013, 10:39 AM
I did install a new OEM servo pin today and I must say that this appears to have made the transmission perfect. It has very little travel. At the bottom of the range 0.075 inches. Thats tight but it is in spec and runs great. I want to thank you for the help in spite of my not being a hotrodder. This place is top notch!
I am thinking about upgrading the servo to a corvette. Im told that it is a good idea for my towing needs as well as for longevity. I do have a wide band in it. Is that thinking right?
4l65E Fluid Contamination c65shoebox Transmission - Rearend 1 02-22-2012 06:41 AM
4l65E no 3/4 2005 Escalade c65shoebox Transmission - Rearend 6 02-18-2012 12:38 PM
4L60E/4L65E transimission rebuild white99dime Transmission - Rearend 9 02-12-2012 10:41 AM
4l65e transmisson frink55 Hotrodders' Lounge 1 05-02-2011 10:27 PM
Will a 4L65E be fine behind a ~460hp LT1? McDeuce Transmission - Rearend 2 08-05-2010 07:48 PM
