4l6oe needs help - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2007, 02:59 AM
4l6oe needs help
hi from trev i have a 4l60e behind a 350 lti motor in a 56 chev i lost 1 2 4th gears after 100 mile drive i drove home in 3rd got up next day drove around for a while alls good till i was driving up my street then i lost 1 2 4 again and speedo is this a gear box problem . i checked connections to box seems ok
Old 12-25-2007, 10:43 AM
sounds like the tranny is going into limp mode reverting to 3rd gear only. check the connections and check the plug on the tranny
Old 12-25-2007, 11:15 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by trevorbg
hi from trev
i drove home in 3rd
Trev,
are you using the OEM wire harness and ECM (computer) ?
As suggested , the trans is going into the limp mode = 3rd gear only.
This is usually the result of a connection problem , loss of voltage and computer feed to the trans.
Check connections (all of them) and the ground wires too! loose pins in the harness connector , poor grounds or no ground hooked up.
Engine properly grounded to the chassis, battery grounds to the engine , chassis.
4L60E turns to slush in od desotot Transmission - Rearend 2 07-22-2007 11:05 PM
Carburetor & 4L6OE UPDATE !!!! SNOOK58 Transmission - Rearend 2 06-28-2006 06:48 PM
How to control my 4L6OE in 99 Tahoe? SNOOK58 Transmission - Rearend 8 06-18-2006 10:05 AM
