4l6oe no 4th gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2008, 11:06 PM
4l6oe no 4th gear
i have a 4l6oe tranny im havein a bit of trouble with, it will not change into 4th gear all other gears work fine and there is no slipping in the tranny. i did a service on the tranny on the weekend hoping that would help but no good. i suspect it could be the 4th shift solarnoid and i was wondering if anyone could help me out
Old 01-17-2008, 05:25 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
year of vehicle?
mileage?
Original trans to the vehicle? was it rebuilt a short while back?
I doubt it is a shift solenoid.
the same shift solenoid functions to make first gear. First gear operates correctly?
probably the band
Edelbrock Gear Drive!~!~ Help!! boneyard Buick Engine 1 05-27-2005 03:59 AM
700 R4 4th gear problem. JOHND. Transmission - Rearend 0 02-04-2004 01:04 PM
Lock Up In Fourth Only. Help 406 ss monte Transmission - Rearend 7 01-15-2004 02:08 PM
Roller cam/distributor gear information Jmark Engine 0 12-29-2003 03:56 PM
AOD lost 4th gear ford5.0supercharged Transmission - Rearend 13 10-16-2002 04:42 PM
