4L80-E Conversions with GM TCM. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2011, 09:24 PM
Hello,
I am in this to help YOU convert your vehicle to a 4L80/85-E transmission WITH the GM diesel TCM controller. I did this with a 77 crew cab dually and a carb. HEI is needed and I installed an electric speedo in mine.
I am a retired GM transmission calibration engineer. I have researched, talked to, and applied at TCI and other transmission controller companys. They have DONE YOU A GREAT INJUSTICE if you purchase this TCM. They HAVE NUMEROUS DEFICIENCYS and WILL burn your transmission clutches up. If you are NOT a gm trans calibrator and worked with the 4L80-E calibrations HOW CAN YOU DESIGN and CALIBRATE THE TCM Correctly?
I can and WILL help you if you would like it. I did it and it works GREAT and IT BULLET PROOF. I did minor mods to the valvebody space plate and NO OTHER MODS like bigger and more clutches. (They are a WASTE OF MONEY).
Is anyone interested in this and you can do this at home. A wiring harness will have to be constructed. There are companys that offer this service like Howell Fuel Injection. This is for the STAND ALONE GM DIESEL TCM APPLICATION and a 4L80/85-E transmission. NO other trans will work, sorry.
The Following User Says Thank You to Billyg38120 For This Useful Post:
lollo (11-03-2015)
4L80 - Where to buy ? x007 Transmission - Rearend 17 04-07-2005 05:19 PM
4l80-E spudman45 Transmission - Rearend 1 10-15-2004 03:02 PM
4l80 *Update* william27103 Transmission - Rearend 2 08-18-2004 01:22 PM
4L80 crossmember 72elcamino Transmission - Rearend 0 07-11-2004 09:06 AM
4l80 id? slider in wa Transmission - Rearend 0 11-12-2003 05:31 AM
