4L80-E slips in R. high line pressures - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2012, 11:23 AM
with harness connector connected pressures are Reverse 270 psi. Drive 130 psi. P-N 65 psi. With harness disconnected pressures are Reverse 280 psi. Park, Neutral, and Drive are 170 psi. Trans. goes into Reverse but slips. Forward gears are OK. fluid isnot burned and no codes. Am at a loss. Help.
Old 02-27-2012, 07:25 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Is the ''check engine'' lite on?
Have you checked for trouble codes?
What year 4L80e trans?
Recent repair work or is the trans high mileage?
Common failure on the 4L80e is a cracked rear band servo. This causes reverse to slip.
If the PCM is seeing a slippage in reverse, the system will raise main line pressure to compensate
high line pressure, 700r4 CaballeroMan Transmission - Rearend 8 05-10-2008 07:32 AM
4L80 - Where to buy ? x007 Transmission - Rearend 17 04-07-2005 05:19 PM
4l80-E spudman45 Transmission - Rearend 1 10-15-2004 03:02 PM
Oil pressures on 400 sbc? Jag Daddy Engine 5 03-21-2004 12:11 PM
4L80E pressures seem high in rev, are they? Jason Transmission - Rearend 6 09-24-2003 09:16 PM
