4L80 non electronic - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2006, 12:32 PM
70 Chevelle SS 396
4L80 non electronic
OK...So the 4L80-E is an electronically controlled overdrive model of the 3L80 (TH 400), basically. I've seen those transmissions sold as non-electronic, manually shifted units, though. Does that mean that you couldn't just put it in "drive" and go- you have to drop it in 1st, then shift to 2nd, etc.? Would that be the same principle as having an automatic transmission with a manual valve body and a ratchet shifter? So, did GM make any non-electronic heavy duty overdrive transmissions?
I was also wondering- If my current cam requires a stall, say 2500-3000, will I be able to drive at part-throttle, low RPM speeds (like around town) without screwing up my converter? I haven't bought a converter yet, 'cause I'm not sure if I'm going to swap cams. Thanks for any advice you can lend
Nooj
Old 03-09-2006, 02:55 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
The only way to make a 4L80E shift without the electronics is to install a manual valve body. It requires the electronic control to operate the shifts on its own.
You could install a manual valve body, put it in drive, and go, but you'll only have one gear and it would be drive. You would very shortly destroy the transmission.
Old 03-09-2006, 03:06 PM
Jmark's Avatar
Here is a link to a fully manual 4L80E trans.
Its shifted manually, 1,2,3,4 and good to a thousand hp! LOL
Help me pick- Electronic Ignition Coil Francis Electrical 27 04-24-2006 05:11 AM
700R4, cruise & electronic speedo 302 Z28 Transmission - Rearend 10 10-31-2003 12:28 PM
Electronic cut out's ? 56f100 Engine 22 09-24-2003 07:42 AM
Help wiht my dead Chrysler electronic ignition willys36@aol.com Electrical 12 07-27-2003 10:02 PM
4L80 to TH400 swap Jason Transmission - Rearend 4 06-14-2003 06:46 PM
