4L80 - Where to buy ? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-15-2005, 10:57 AM
ronb's Avatar
Will have to build a custom crossmenber anyway , can't find any one that build one for a 4l80 an F-body 82-92.. Even sponh dont have it [/QUOTE]
If i were doing this setup? I would start by relocating the stock crossmember frame bolt locations and use Helicoil inserts with grade 8 bolts and try using the stock cross-member with center bolt modified for the 4L80 mount? but then again I cannot see exactly what you have to work with?? just some idea`s
  #17 (permalink)
Old 03-17-2005, 07:18 AM
x007's Avatar
Supercharged T/A
If i were doing this setup? I would start by relocating the stock crossmember frame bolt locations and use Helicoil inserts with grade 8 bolts and try using the stock cross-member with center bolt modified for the 4L80 mount? but then again I cannot see exactly what you have to work with?? just some idea`s [/QUOTE]
I dont think i woul be able to bolt it on the frame, the trans support will be too far i think... anyway will see.. thanks..
  #18 (permalink)
Old 04-07-2005, 06:19 PM
x007's Avatar
Supercharged T/A
Just Got my 4L80 from Phoenix Transmission !!!
Look at this beautifull baby,
4L80 build to Handle 1000HP+,
2004 Housing, Compushift whit Display
This trans is incredibly nice !
[IMG][/IMG]
-= Build for Power =-
Would you buy the Hot Rod or a Diamond for Your Girl? Tell Us! prismstar Hotrodders' Lounge 2 06-04-2006 06:21 PM
don"t buy from HF ratfink14 Garage - Tools 64 08-09-2005 10:48 PM
Best Buy kristkustoms Hotrodders' Lounge 16 12-23-2004 08:46 PM
what kind of power tools do you buy??? mustangman1968 Garage - Tools 0 04-14-2004 02:58 PM
what are you going to buy? akm Hotrodders' Lounge 11 11-15-2003 03:18 PM
