4L80 yoke in a 4L60 trans ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2007, 02:45 PM
Billvill's Avatar
Does anyone know if the drive-shaft transmission yokes are interchangeable between a 4L60 and 4L80 automatic. I have a 4L80 aluminum drive-shaft I want to put in my 4L60 van. The rear large yoke for a 10 bolt is avaliable and is not a problem. Hoping someone here can save me the hours time to remove my existing shaft and check the new one.
Anyone ?
Old 05-06-2007, 03:48 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Anyone ?
No , they are NOT the same
Old 05-07-2007, 11:20 AM
Billvill's Avatar
That wasn't the answer i wanted. LOL thanks for the reply.
Old 05-07-2007, 08:54 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
it is what it is..... a t-350 size yoke to a t-400 size yoke. They do not interchange .
TH350 driveshaft yoke leaking Jmark Transmission - Rearend 11 08-16-2008 11:38 AM
4l80 Elec. Trans. controler - Compushift - Tcom(tci) - PCS etc.. x007 Transmission - Rearend 0 03-08-2005 05:19 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
Installing a slip yoke trans with a two piece d-shaft Jason Transmission - Rearend 8 11-27-2003 01:49 PM
4L80 Trans Gassman Transmission - Rearend 5 02-14-2003 04:53 AM
