4l80e - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2011, 05:27 PM
4l80e
I have an 02 chevy silverado z71 with a 327, will be putting in a cam and other sorts of things down the road but am in need of a tranny right now, should i upgrade to a 4l80e tranny since i have to buy one anyway,? and does it bolt right up to the motor like a 4l60e would?
Old 08-20-2011, 09:11 PM
Crosley's Avatar
Wiki Edits: 1659
Are you talking an early version of 327 chev engine?
TO swap to the 4L80e , you need a controller for the transmission.
If you are using the OEM computer, you will need to re-wire a few pins in the connector for the 4L80e trans or use an adapter pig tail.
The computer will also need some re-programing.
The yoke for the transmission is larger - different splines from a 4L60e
Drive line will need to be shortened or find a proper length drive line with correct yoke for the 4L80e
4l80e Stanley H Transmission - Rearend 0 10-03-2007 12:37 AM
4L80E in Jag? carnuck Transmission - Rearend 2 06-03-2004 09:06 PM
4l80e jeason Transmission - Rearend 6 04-22-2004 06:55 PM
4l80e njbloodline666 Transmission - Rearend 3 01-08-2004 11:06 PM
