4L80E - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2003, 06:54 AM
smuhammad's Avatar
New Member
Post 4L80E
okay,
I have been getting great responses, Thanks Alot.
Now,will the 4L80E from a 1992-96 Caddy Fleetwood bolt up to my Buick or is that caddy using a Chevy engine ?
Is there a conterpart to this modern trans ?
Old 01-06-2003, 01:37 PM
New Member
Post
The 4L80E is not in Caddys its only in trucks, behind BBC's and Diesels.
Old 01-06-2003, 03:04 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
In the 90s GM changed the names of all their trannys to totally confuse the issue. The 3L80 is the same as the old TH400. The 4L80 is an overdrive version of the TH400 and the 4L80E is the electronic OD version. On that basis it is a heavy duty tranny and should be found in trucks like the old TH400 was as JoeyP says.
Old 01-19-2003, 06:50 PM
xtreme off-road's Avatar
Post
The 4l80E was also behind a 4 bolt 350 in the 2500HD and 3500.
