4L80e brake - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2008, 09:20 AM
4L80e brake
Hi,
I'm now planning my parking brake installation for a street rod project with a 4L80e.
I wanted to avoid running brake cables to rear calipers and I was told that motorhomes had 4L80e transmissions with a brake assembly mounted to the trans tailshaft.
Is this something to consider so I can connect to a gennie or lokar floor mounted emegency brake handle to the trans.
Thank you for your help.........
Old 10-18-2008, 10:47 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Look to hummers and HD trucks. They had them.
Old 10-19-2008, 07:03 AM
Hi,
I already have the 4L80e trans.
Does anyone know where I can get the tailshaft that has the mechanical parking brake assembly?
What is it actually called, any pictures, etc.
Thanks again....
Old 10-19-2008, 08:41 AM
Originally Posted by powerplay13
Hi,
Thanks again....
The trans-mounted parking brake requires a bolt-on yoke, which requires a different output shaft on the trans. The output shaft is the first thing that goes into the bare case, so you need to completely disassemble the trans to change it.
Old 10-19-2008, 09:47 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
All of the 2WD out put shafts I have seen on a 4L80E , they are all bolt on style shafts.
The 4x4 shafts are different.
The E brake tail housing design of the 4L80E will require the whole tail housing , brake and yoke.. these parts are all application specific.
This brake assembly is quite large diameter and may not easily fit under the floor of most cars.
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
It's a Mustang II, but what's in it? And a brake problem . . . hduff Suspension - Brakes - Steering 4 11-19-2006 06:00 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
