Hotrodders Bulletin Board
#1
4L80E diesel computer
I have a '86 GMC dually 1ton 4x4, that I would love to have a 4L80E in, in place of the th400. I know I can get a trans computer from Jet and others in the aftermarket, but they're pretty pricey. I've seen bits and pieces online of people talking about using the trans computer out of late model diesel trucks, but nothing definitive. Can anyone on the list point me to some solid info on the use of this computer? Thanks.
#2
re: 4L80E diesel computer
just my opinion here , so please take it as that...
Diesel computer is old tech to control the 4L80E. Get the Comp U shift. We have used them in several applications..... 4L60E , 4L80E , AODE. Very programable. The Tech guys at Comp U shift have helped us with stuff. There are also some back doors into the programming to even more stuff with the Comp U shift.
======== If you can't fix it with a hammer, you have an electrical problem. |
#3
The Compushift is the route I'm going as well. Thought about a TCI....no technical support whatsoever unless you call FAST and bother them.
The thing on the compushift is that you MUST buy the little display with the 4 square buttons on it to do the back door programming. You can even set it up to do lockups based on percentage of throttle all the way up to WOT, but you must have the programmer. If you really want to go the diesel route, look here: www.tunercat.com $D3 16128420 92 - 93 C/K Diesel Truck L65, Auto Trans, TCM I sent them a bin that I pulled out of a diesel trans contoller's prom and they had it broken down in like 4 hours. Here's a list of everything that was in the bin: ECM Switch Parameters Output Speed Low Diag. (Error 24) Trans Press Switch Diag. (Error 28) Brake On Diag. (Error 37) Brake Off Diag. (Error 38) System Voltage High Diag. (Error 53) Trans Temp High Diag. (Error 58) Overdrive Diag. (Error 68) TCC On Diag. (Error 69) Engine Speed Low Diag. (Error 71) Output Speed Loss Diag. (Error 72) Trans Temp Low Diag. (Error 59) Force Motor Current Diag. (Error 73) Input Speed Sensor Diag. (Error 74) System Voltage Low Diag. (Error 75) Transmission Hot Diag. (Error 79) Quad Driver 1 Shift B Diag. (Error 81) Quad Driver 1 Shift A Diag. (Error 82) Quad Driver 1 Diag. (Error 83) Undefined Ratio Diag (Error 85) Low Ratio Diag. (Error 86) High Ratio Diag. (Error 87) Manual Mode Enable (X = Disabled) Downshift Turns Off TCC (X = Yes) Rapid TPS Decr. Turns Off TCC (X = Yes) Very Low TPS Turns Off TCC (X = Yes) Hot Trans.Turns Off TCC (X = Yes) Cold Trans.Turns Off TCC (X = Yes) Cold EngineTurns Off TCC (X = Yes) Gradual TCC Release (X = Enabled) ECM Constants Mechanical 1st Gear Ratio Mechanical 2nd Gear Ratio Mechanical 3rd Gear Ratio Kickdown Mode Enable %TPS Threshold Kickdown Mode Disable %TPS Threshold Low PRNDL Upshift Speed Threshold Low PRNDL Downshift Speed Threshold Drive2 PRNDL Upshift Speed Threshold Drive2 PRNDL Downshift Speed Threshold Manual Mode 2->3 Shift Speed Threshold Manual Mode 3->2 Shift Speed Threshold Manual Mode 3->4 Shift Speed Threshold Manual Mode 4->3 Shift Speed Threshold Pressure Reduction for 1->3 Upshift 1->3 Upshift Pressure Reduction Time Pressure Reduction for 1->4 Upshift 1->4 Upshift Pressure Reduction Time Pressure Reduction for 2->4 Upshift 2->4 Upshift Pressure Reduction Time Garage/Normal Shift Speed Thresh (P/N) Garage/Normal Shift Speed Thresh (Drive) Garage/Normal Shift Press Delta (P/N) Garage/Normal Shift Press Delta (Drive) Garage/Normal Shift Press Delta (Rev) Lower Adaptive Learn Trans Temp Thresh. Upper Adaptive Learn Trans Temp. Thresh. Adaptive Learn Modifier Lower Limit Adaptive Learn Modifier Upper Limit Hot Transmission Enable Temp. Threshold Hot Transmission Disable Temp. Threshold TCC Enable Coolant Temp. Threshold TCC Disable Coolant Temp. Threshold TCC Enable Cold Trans. Temp. Threshold TCC Disable Cold Trans. Temp. Threshold TCC Enable Hot Trans. Temp. Threshold TCC Disable Hot Trans. Temp. Threshold TCC Disable TPS Threshold - Low MPH TCC Disable TPS Threshold - High MPH Min TPS to Enable TCC - Low MPH Min TPS to Enable TCC - High MPH Low-High MPH Thresh. for TCC TPS Limits High-Low MPH Thresh. for TCC TPS Limits Low Neg. Delta %TPS TCC Release Thresh. Low Neg. Delta %TPS TCC Release Time High Neg. Delta %TPS TCC Release Thresh. High Neg. Delta %TPS TCC Release Time Downshift TCC Release Time Max Time Between Engine Pulses Engine Pulses Per Revolution Input Speed Cal Pulses Per Revolution Max Time Between Trans Input Pulses Output Shaft Pulses Per Revolution Max Time Between Trans Output Pulses Overdrive Ratio PROM ID Tables ECM Switch Table ECM Constant Table Normal Mode Main Line Pressure, 0 - 64 MPH Normal Mode Main Line Pressure, 64 - 128 MPH Performance Mode Main Line Pressure, 0 - 64 MPH Performance Mode Main Line Pressure, 64 - 128 MPH Main Line Pressure Vs. TPS Vs. Trans. Temp. (2nd) Main Line Pressure Vs. TPS Vs. Trans. Temp. (3rd) Main Line Pressure Vs. TPS Vs. Trans. Temp. (4th) Normal Mode Pressure Offset (psi) Vs. TPS Vs. Gear Perf Mode Pressure Offset (psi) Vs. TPS Vs. Gear Down Shift Pressure Modifier 2 -> 1 Vs. MPH Down Shift Pressure Modifier 3 -> 2 Vs. MPH Down Shift Pressure Modifier 4 -> 3 Vs. MPH Line Pressure Modifier In WOT Vs. RPM Pressure Correction for A/C On Vs. Gear Engine Breaking Force Motor Pressure Vs. MPH Vs. G Adaptive Pressure Modifier Vs. Shift Time Error Adaptive Cell TPS Boundaries Adaptive Learn TPS Limits Vs. Gear Normal Mode Upshift/Downshift Vs. MPH Vs. TPS Performance Mode Upshift/Downshift Vs. MPH Vs. TPS Desired Shift Time (sec) Vs. %TPS Vs. Gear Kickdown Up/Down Shift Points Hot Kickdown Up/Down Shift Points Shift Ratio Threshold vs Shift Gear Ratio Limits For Error Diagostics 85, 86 & 87 Garage Shift Press Vs Trans Temp Vs Input Spd, Drv Garage Shift Press Vs Trans Temp Vs Input Spd, Rev Rolling Garage Shift Press (psi) Vs. MPH Vs %TPS Norm Mode Torque Converter Release MPH Vs. TPS Norm. Mode Torque Converter Apply MPH Vs. TPS Perf. Mode Torque Converter Release MPH Vs. TPS Perf. Mode Torque Converter Apply MPH Vs. TPS Hot Mode Torque Converter Release MPH Vs. TPS Hot Mode Torque Converter Apply MPH Vs. TPS TCC Apply/Release Speed at WOT Vs. Gear TCC Hot Apply/Release Speed at WOT Vs. Gear TCC Release Rate Vs. %TPS TCC Apply Operating Point Vs. %TPS TCC Release Operating Point Vs. %TPS Operating Point Multiplier Vs. Pressure TCC Max Time in Release Before Slip Vs. %TPS TCC Max Time in Release After Slip Vs. %TPS TCC Apply Rate Vs. %TPS Minimum TCC Duty Cycle Vs. Torque Pressure Maximum TCC Duty Cycle Vs. Torque Pressure Force Motor Current Vs. Desired Pressure Unless your ready to dive into all these different parameters, better to get a standalone unit. Remember, you've got to wire it all up too. |
Back to top |
Similar Threads for: "4L80E diesel computer"
| Basic Computer Safety | strikingthematch | Hotrodders' Lounge | 6 | 02-03-2005 03:12 AM |
| First 4L80E build questions. | bugsdad | Transmission - Rearend | 12 | 10-22-2004 06:40 PM |
| 4L80E transmission | Seon | Transmission - Rearend | 7 | 11-12-2003 05:59 PM |
| Smoked computer during start | Chadman | Engine | 3 | 08-20-2003 11:12 AM |
| Fuel Injection Computer | Big Mac | Engine | 0 | 12-04-2002 02:42 PM |
