4l80E Direct and Forward drum piston interchange - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2011, 11:27 AM
Hey guys, new to the forum here. Ive searched and think i may have found my answer, but want to double check. I have a 94 4l80e and the direct piston cracked. I want to replace the direct and forward drum pistons with the bonded steel pistons. It has the aluminum pistons at this time. Are the bonded pistons interchangeable to use in 94 model direct and forward drums? Thanks for your help in advance. Much apprecaited.
-Matt
Old 01-05-2011, 06:55 PM
Crosley's Avatar
Wiki Edits: 1659
If I understand the question;
the bonded pistons are direct replacement for the aluminum pistons. I never re-use aluminum pistons in 4L80e
Most bonded pistons are marked for proper drum fitment. the center area is different size seal for each drum. Forward drum center seal is smaller
Old 01-05-2011, 07:42 PM
Thanks for the reply. Much appreciated. I went ahead and installed the bonded steel pistons and they fit fine and pressure checked fine. The gentlemen i bought the kit off ebay from said they will not interchange. Not sure where he got his info. Anyhow, thanks again.
Old 01-05-2011, 08:53 PM
Crosley's Avatar
Wiki Edits: 1659
You can install the direct drum bonded piston into the forward drum.. Problem is the bottom steel plate can then drop below the grooves for the steel plate. The plate will then bind up the piston and cause a 'no apply' situation
Old 01-05-2011, 09:25 PM
Ya I noticed when looking at the pistons where they were marked direct and forward. Everything seemed fine when I air checked it. Thanks again for the help. I was just kinda lost when i called the trans shop on why they didn't send me the steel pistons like they were supposed to and he stated 97 and up only had them and damage will occur on 96 and down.
TH350 - 36 Element Direct Drum Conversion ride00007 Transmission - Rearend 8 12-14-2010 06:25 PM
T-350 Direct Drum Dino383 Transmission - Rearend 2 11-30-2010 09:14 PM
Direct Drum frickenbored Transmission - Rearend 24 03-30-2010 04:03 AM
TH350 direct drum band wobbles in goo tubbedz Transmission - Rearend 2 07-30-2008 03:31 PM
Torrington Bearing between Direct and forward drum? 6426yy Transmission - Rearend 2 05-05-2008 02:28 PM
