Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4l80e no reverse
Old 04-06-2006, 07:20 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
have you checked for blown out/cracked walls of the fluid circuit of the case?
Is the band servo piston cracked in the area of the seal? I've seen servos that look great till you really look at the seal groove area.
