4l80e no reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2006, 01:55 PM
tnsmith10's Avatar
when will it rain???
4l80e no reverse
hey crosley or chasmac, we got a 4l80e in with no reverse and on the rdi, we found absolutely nothing wrong with it...
according to the customer, he was going down the road and inadvertantly, his kid was moving around and "accidentaly" hit the shifter and knocked it into reverse., he said that for a few days, it would apply, but he would have to give it some gas to move, but after a few times, it just quit working. were kind of thinking case, and possibly valve body..
as fas as how it worked (minus reverse), it works great. t.c.c. apply in 3rd. all ranges on time, and good shifts... i pulled a couple engine codes, but nothing i found relavance to the situation... any ideas?
Old 04-06-2006, 06:29 PM
airworld2's Avatar
low reverse band broken or bad.... with out tear down thats the best bet.....
Old 04-06-2006, 07:20 PM
Crosley's Avatar
Wiki Edits: 1659
have you checked for blown out/cracked walls of the fluid circuit of the case?
Is the band servo piston cracked in the area of the seal? I've seen servos that look great till you really look at the seal groove area.
Old 04-06-2006, 09:07 PM
tnsmith10's Avatar
will check 1st thing in the morning... thx
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Car Will Not Go Into Reverse?? HotRodMan Transmission - Rearend 15 05-22-2007 02:33 PM
Making a reverse shape in sheet metal John Kelly Body - Exterior 4 12-16-2005 08:24 PM
Need some tranny help. 4l80e Bruce Wang Transmission - Rearend 3 09-19-2005 03:19 PM
First 4L80E build questions. bugsdad Transmission - Rearend 12 10-22-2004 07:40 PM
th350 reverse double apply??? eskoskimo Transmission - Rearend 1 10-11-2004 05:07 AM
