4L80E question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2013, 02:38 AM
sqeezeit's Avatar
4L80E question
Did a search already but didnt find any answers just thoughts and maybes.I have a 4l80e out of a (cant remmber the year till i get home) chevy 2500 4x4 but want to make it a 2wd for my rod.I have a tail housing but heard the shaft is different length also.If so is it easy swap and also heard about sum seal differences with plates or something.I thought I would be able to just put shaft and tail housing on and good to go?Also does anyone have any recommendations on stand alone controllers for these (smart shift,compushift,ez tcu,us shift ect...)which one works best with least problems(glitches) and do they work with all years of the 4l80e?
Old 04-08-2013, 06:02 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You need to remove the complete trans internals to change the out put shaft. Valve body removal is required too.
Make sure you find the correct output shaft for the lubrication circuit. there will be holes in the shaft for oil transfer or not depending on year of this trans
Then : on a 4x4 case, you need to remove a cup plug at back of case, install another cup plug with small hole. This cup plug also has an O-ring on it to seal up against the tail housing. This provides oil pressure to the tail housing bushing.
I do not conceder this a DIY first time inside a trans friendly job
Old 04-09-2013, 12:00 AM
sqeezeit's Avatar
Thanks for info wasnt awhere of that.So as far as shafts go they have sum with & without lube holes for bushing,then I just get what I need for what year my tranny is I take it? Do you know what years 4l80e fit on sb cheys?I assume when they where bolted to ls/lt motors they are 7 bolt not 6,but heard you can still use on sb just not the other way around?Thanks again
Old 04-09-2013, 12:02 AM
sqeezeit's Avatar
Forgot to ask where to I get the plug to change out on 4x4 one to oil shaft,and good place for other parts I need if you know.Thanks again
4L80e Tranny Question peetyweet Transmission - Rearend 5 01-20-2011 11:55 AM
4L80E Yoke question propaneburner Transmission - Rearend 2 01-24-2009 01:34 AM
4l80e question. SdimeSS84 Transmission - Rearend 3 05-22-2007 08:15 PM
4L80E question BLOWN 1100 Transmission - Rearend 3 09-04-2004 10:51 PM
4l80e njbloodline666 Transmission - Rearend 3 01-08-2004 11:06 PM
