-   -   4l80e - selector switch q (http://www.hotrodders.com/forum/4l80e-selector-switch-q-120269.html)
eliotmansfield 07-16-2007 05:46 PM
Hi,
I have the opportunity to purchase a 4l80e - BUT it has a broken selector switch on the side of the box:
http://homepages.nildram.co.uk/~eliotmez/4l80e-side.jpg
Can anyone confirm if this is needed with an aftermarket controller? - I thought the lever position was deturmined by internal switches - is this just for the dashboard or something?
thanks,
Crosley 07-16-2007 06:11 PM
that is a MLPS ; Manual Lever Position Sensor and is needed fpr the OEM application for the PCM to know where the shift lever is.
I do not know of an after market controller that use the MLPS
jakeshoe 07-16-2007 06:18 PM
Yep,
You can remove that for an aftermarket controller. You can also retrofit an early 4L80E manual shaft so it is shorter.
Have fun getting the "nail" out. :)
The MLPS's are always broken, I can never get the connectors loose without damaging them. $35 new, I just replace them. IIRC there was a GM TSB on those because of the sealant.
Crosley 07-16-2007 06:24 PM
Originally Posted by jakeshoe
Yep,
heat the connector area up with a lighter or a small butane torch... they come apart easily then for me.
jakeshoe 07-16-2007 08:45 PM
Tony,
Me and a torch under a car = disaster. :D
I spent too long practicing to destroy stuff to be able to safely use fire.
Here's the underside of one I've been under lately. :cool:
http://i32.photobucket.com/albums/d8...ustangbot2.jpg
