4l80E/T-400 parts interchange? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2010, 05:00 PM
Semper Gumby
Wiki Edits: 2
I checked the knowledge base first - honest!
The 4L80E in my '92 GMC 2500HD pickup has suddenly lost reverse gear. Other web sources tell me that either the reverse gear servo piston or the third gear /reverse clutch drum assembly or the reverse band are most likely to be the guilty culprits. The "klutz" drum and band will require a total trans re-do if they are the ones that need it, but the servo can be reached by just dropping the pan.
Since the servo is easy to get at, I thot I'd try that first. The GM part number for the servo piston assembly seems to cross to the same thing in TH400 (Part number TH400.PIS04)
Anyone know if it IS the same? (I have a late model TH-400 I can cannibalize if this will work)
If I gotta go into the whole trans - I won't as I can get a used 4L80E in running condition for $300.00. The whole truck not worth the cost of re-doing the trans
Symptoms:
Drives perfectly in all gears, going forwards
2 nites ago, my son took it to the store and when he was backing out of the parking spot, it backed up a couple of feet, went "bang" and then the RPM came up while the truck stopped moving.
Now we can't even park in the driveway as we could not get back out again!
GRRRR!!!!
Old 08-29-2010, 10:10 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
If you use a t-400 servo as replacement, make sure you have the matching cover.
4l80e servo piston can crack around the groove for the square cut rubber seal
your 1992 trans should have the early design and will match up to the t-400 parts
There is the possibility that 'pop' noise was the rear band breaking
4l80E Direct and Forward drum piston interchange blade42003 Transmission - Rearend 4 01-05-2011 09:25 PM
Parts interchange? pumpkin35 Engine 7 02-11-2005 04:16 PM
parts interchange griffinzein Engine 1 11-29-2004 05:47 AM
Yoke interchange for 4L80E Jason Transmission - Rearend 4 09-15-2003 04:30 PM
Got some more 4L80E interchange questions Jason Transmission - Rearend 2 09-12-2003 07:18 PM
