4L80E tailshaft housing - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2005, 06:49 PM
I just picked up a 4L80E out of a 2000 chevy truck. I am going to replace the 700r4 that is currently in my truck (1986 Chevy). My question is about the extension/tailshaft housing. The one I got originially had a two-piece driveshaft, with bolt-on yoke. Does anyone know if this can be replaced with a slip yoke? I haven't been able to find much on the subject. As far as I can see, all 4L80E's use the same rear seal and bushing. I also plan to install Transgo's stick shift kit. Anyone have experience with these?
Old 02-22-2005, 10:01 AM
4L80E transmissions work SO GOOD electronically, especially the later ones like you have. Get a FAST system an install it. I have done several of these installs at my shop. The programming software makes these trans work GREAT!
The output shaft on the 4L80 is yoke specific. To change to a slip yoke style will require complete trans disassembly. Rather than do that, have your driveshaft guy build the shaft with a slip spline in the shaft itself. It will work, and it is much simpler.
Old 02-27-2005, 10:56 PM
Well, after doing some more searching, I found the following information: Only two output shafts were used (2-wheel and 4-wheel drive), and there isn't a specific slip yoke tailshaft or housing. I may just use the bolt in yoke I have and have my driveshaft changed to include a slip joint. I am also going to build my own tranny controller, it will be manually shifted through forward gears by buttons the steering wheel. Should be pretty neat when finished.
First 4L80E build questions. bugsdad Transmission - Rearend 12 10-22-2004 08:40 PM
Uncurable Extension Housing Leak skizot Transmission - Rearend 8 09-04-2004 12:00 PM
turbo 400 tailshaft housing ? 85406 Transmission - Rearend 5 08-28-2003 06:35 PM
bell housing identification Leesz Engine 0 01-04-2003 02:58 PM
bell housing identification Leesz Transmission - Rearend 0 01-04-2003 02:54 PM
