4L80e Tranny Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2011, 11:43 AM
I need to find a stand alone computer to operate a 4L80e transmission....I heard somewhere that some of the old diesel chevy trucks have them....does anyone know the year, make, & model of the trucks that have the stand alone module in it??? Thanks
Old 01-19-2011, 12:35 PM
I can't help with the years at the moment but to get you pointed in some kind of direction if you have trucks to rob, look for the ones with throttle cables - these were mechanical injection. Don't confuse the kickdown cables for throttle.
Old 01-19-2011, 01:56 PM
1991-93 GM diesel trucks. Staring in 1994 the diesels were computer controlled also, so the trans control was integrated in the engine computer.
Old 01-20-2011, 10:41 AM
tnsmith10's Avatar
when will it rain???
the 4L80E never had a throttle valve cable...
Old 01-20-2011, 11:32 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
He's looking for the trucks WITH the computer.
94 ish through 2000 ish. If its a 6.5 turbo with a 4 speed auto, its a 4L80E. The reason they are a good starting point is because they control the transmission, but there are very limited things about the engine that they control.
There is still some significant modification you need to do to the computer, but you can make them work for pretty inexpensively. The problem is programming them.... that's still pretty much aftermarket territory unless you spend about $1000 on EFILive plus hardware
Old 01-20-2011, 11:55 AM
He's looking for the standalone 4L80E computer that was only used in the 1991-93 diesel trucks as I noted above. The 94-up trucks have an integrated engine/trans computer that can't be used in standalone mode.
6.0 LQ9 engine and 4L80E tranny 49 plymouth snids53 Engine 6 06-16-2009 07:27 PM
4l80e question. SdimeSS84 Transmission - Rearend 3 05-22-2007 08:15 PM
Jet 4l80e Tranny Chip Concern ALASKAN Transmission - Rearend 3 04-11-2006 08:02 PM
Need some tranny help. 4l80e Bruce Wang Transmission - Rearend 3 09-19-2005 03:19 PM
4L80E question BLOWN 1100 Transmission - Rearend 3 09-04-2004 10:51 PM
