4l80e trans swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2011, 04:59 PM
4l80e trans swap
how can i make a 4l80e trans shift smooth , in essence hook up force motor to map sensor on a motor that never had this transmission or any other computorized trans
Old 04-23-2011, 11:35 PM
Are you asking how to use a 4l80e on something without a computer?
There are 2 ways first is a transgo hd3 kit which makes the trans manual shift all the time. Requires a bunch of work on the valvebody. The second is to use a electric control box, I got mine from rossler trans. It makes the trans stick shift as well. The nice thing about the rossler is you can go to a computer at any time, the transgo is a permanent change, plus the rossler is very easy plug and play. Whatever kit you go with I recommend the transgo vacuum can that controls the line pressure according to vacuum.
If you don't want it to shift hard follow the instructions with the vac can and if you put a shift kit in it, transgo hd2, don't drill the orifices.
4L60E trans vs 4L80E pavetim Transmission - Rearend 6 11-26-2009 11:42 AM
swap turbo 400 to 4l80e mick58 Transmission - Rearend 2 11-17-2009 06:51 PM
Replace manual trans with 4L80E - 1999 chevy dually tryc Transmission - Rearend 11 08-23-2008 11:06 AM
4l80e trans strength.. bb chevelle4542speed Transmission - Rearend 4 07-28-2007 08:44 AM
Trans Swap 4l80e In 69 Camaro NU BREED Transmission - Rearend 2 08-16-2003 11:28 AM
